Salta al contenuto principale
Introduzione
Amazon’s Kindle Paperwhite 3 (7th Generation) possesses a 3.7 Volt, Lithium Polymer battery (Model No: MC-354775-05). This guide requires that the Kindle is turned off, and that a plastic opening tool, and a PH000 screwdriver are used.
  1. Ensure that the device is turned off before beginning. Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point. Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
    • Ensure that the device is turned off before beginning.
    • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
    • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
  2. Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame. Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
    • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
  3. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  4. Gently lift the mid-frame out of the case with your hands.
    • Gently lift the mid-frame out of the case with your hands.
  5. Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery. Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
    • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
  6. Gently lift the battery from the frame.
    • Gently lift the battery from the frame.
Conclusione
Altre 28 persone hanno completato questa guida.
Micah Smart
Membro da: 10/02/2016
1.629 Reputazione
3 Guide realizzate
USF Tampa, Team 14-3, Lacy Spring 2016 Membro di USF Tampa, Team 14-3, Lacy Spring 2016
USFT-LACY-S16S14G3
4 Membri
6 Guide realizzate
Same for 5th Generation ??
PAUL FRIEND - Replica
where can i buy a new battery ?
david horn - Replica
you need a taobao.
lol
kassadin -
where can I buy a replacement battery?
boelens - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 28
Ultimi 7 Giorni: 164
Ultimi 30 Giorni: 904
Tutti i Tempi: 19,266
