Salta al contenuto principale
Kindle Paperwhite 2nd Generation Screen Replacement
Cosa ti serve
  1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Screen Replacement: passo 2, immagine 1 di 2 Kindle Paperwhite 2nd Generation Screen Replacement: passo 2, immagine 2 di 2
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Screen Replacement: passo 3, immagine 1 di 1
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Screen Replacement: passo 4, immagine 1 di 1
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
Conclusione
Altre 7 persone hanno completato questa guida.
Tyler Davis
Membro da: 09/15/16
1.869 Reputazione
5 Guide realizzate
USF Tampa, Team 11-2, Blackwell Fall 2016 Membro di USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Membri
17 Guide realizzate
3Commenti sulla guida
My opening tool is orange. Will this still work for me?
FoxRunTime - Replica
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Replica
Did this work Liam?
Ben Lowdon -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 139
Tutti i Tempi: 14,292
