Salta al contenuto principale
Kindle Paperwhite 2nd Generation Motherboard Replacement
Cosa ti serve
  1. Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
    • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
  2. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 2, immagine 1 di 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 2, immagine 2 di 2
    • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 3, immagine 1 di 1
    • Carefully remove the mid-frame from the back cover.
  4. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 4, immagine 1 di 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
  5. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 5, immagine 1 di 1
    • Carefully lift the battery and remove it from the device.
  6. Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
    • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
  7. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 7, immagine 1 di 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 7, immagine 2 di 2
    • Gently disconnect the zif connectors.
    • Some of these connectors are very thin and fragile, handle with care!
  8. Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 8, immagine 1 di 3 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 8, immagine 2 di 3 Kindle Paperwhite 2nd Generation Motherboard Replacement: passo 8, immagine 3 di 3
    • Gently remove the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Tyler Davis
Membro da: 09/15/16
1.574 Reputazione
5 Guide realizzate
USF Tampa, Team 11-2, Blackwell Fall 2016 Membro di USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,200
