Salta al contenuto principale
Kindle Paperwhite 1st Generation Case Replacement
Cosa ti serve
  1. Kindle Paperwhite 1st Generation Case Replacement, Case: passo 1, immagine 1 di 2 Kindle Paperwhite 1st Generation Case Replacement, Case: passo 1, immagine 2 di 2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
  2. Kindle Paperwhite 1st Generation Case Replacement: passo 2, immagine 1 di 3 Kindle Paperwhite 1st Generation Case Replacement: passo 2, immagine 2 di 3 Kindle Paperwhite 1st Generation Case Replacement: passo 2, immagine 3 di 3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
  3. Kindle Paperwhite 1st Generation Case Replacement: passo 3, immagine 1 di 1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 3-33, Amido Winter 2013 Membro di Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 Membri
17 Guide realizzate
2 Commenti
Thanks for the guide but do you know anywhere can we get a replacement case?
jerryw - Replica
4 years too late but I found this
Pao-Tang Kao - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 73
Tutti i Tempi: 9,168
