Salta al contenuto principale
Kindle Fire Motherboard Replacement
Cosa ti serve
  1. Kindle Fire Motherboard Replacement, Back Case: passo 1, immagine 1 di 3 Kindle Fire Motherboard Replacement, Back Case: passo 1, immagine 2 di 3 Kindle Fire Motherboard Replacement, Back Case: passo 1, immagine 3 di 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Where can I buy a battery for my kindle fire
    nannyto2 - Replica
    Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
    vvenona1954 - Replica
    Remember to remove any sd card first!!! Snapped mine in half.
    lucy_lady_bug - Replica
    I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
    Kris Sanders - Replica
  2. Kindle Fire Motherboard Replacement: passo 2, immagine 1 di 1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Mine has another plastic pc over the m.etal plate
    Keith Long - Replica
  3. Kindle Fire Motherboard Replacement, Battery: passo 3, immagine 1 di 3 Kindle Fire Motherboard Replacement, Battery: passo 3, immagine 2 di 3 Kindle Fire Motherboard Replacement, Battery: passo 3, immagine 3 di 3
    • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
    • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  4. Kindle Fire Motherboard Replacement: passo 4, immagine 1 di 1
    • Repeat the process from the previous step to free the left battery cell.
    The CPU got extremely hot and just now getting repaired 5 days or so
    Kelli Sabashion - Replica
    I can't get the battery to charge
  5. Kindle Fire Motherboard Replacement: passo 5, immagine 1 di 2 Kindle Fire Motherboard Replacement: passo 5, immagine 2 di 2
    • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
    • Pull the battery out of the Kindle Fire.
  6. Kindle Fire Motherboard Replacement, Speaker Cable: passo 6, immagine 1 di 3 Kindle Fire Motherboard Replacement, Speaker Cable: passo 6, immagine 2 di 3 Kindle Fire Motherboard Replacement, Speaker Cable: passo 6, immagine 3 di 3
    • Peel the tape on the upper-left IC that is securing the speaker cable.
    • Use the flat end of a spudger to push the speaker connector out of its socket.
    • Deroute the speaker cable so that it will not interfere with the motherboard.
  7. Kindle Fire Motherboard Replacement, Motherboard: passo 7, immagine 1 di 3 Kindle Fire Motherboard Replacement, Motherboard: passo 7, immagine 2 di 3 Kindle Fire Motherboard Replacement, Motherboard: passo 7, immagine 3 di 3
    • Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
    • Use a plastic opening tool to release the touchscreen controller connector.
    • Gently remove the touchscreen controller by lifting it up and to the right.
    • Be careful not to rip the ribbon cable in doing so.
  8. Kindle Fire Motherboard Replacement: passo 8, immagine 1 di 3 Kindle Fire Motherboard Replacement: passo 8, immagine 2 di 3 Kindle Fire Motherboard Replacement: passo 8, immagine 3 di 3
    • Use a plastic opening tool to flip open the power button ZIF connector.
    • This connector will not be removed until the motherboard is free.
    • Flip open the ambient light sensor ZIF socket with a plastic opening tool.
    • Use a pair of tweezers to pull the blue tab on the ambient light sensor cable to remove it from its socket.
    Make sure to mark what ZIF connector goes where, they are not interchangeable even though a first glance the appear to be the same size
    David Alvarez - Replica
    It took about 2 hours, but that is, mainly, because reconnecting the ZIF connectors can be overly tedios.
    Apparently not all Kindle Fires have the ambient light sensor; This connector is not present on mine.
    diprosew - Replica
    I cannot get the zif connectors to go back in ..what can i do...been trying for hours to get them back in...im talking bout the white flip pieces that lock in film..some one please help me with this!!
    bearangel246 - Replica
    Stand it up on its end, lining up the holes to the wires. Slide into holes and 'flip'/rotate white plastic piece down into a flat position.
    toniamosley -
  9. Kindle Fire Motherboard Replacement: passo 9, immagine 1 di 3 Kindle Fire Motherboard Replacement: passo 9, immagine 2 di 3 Kindle Fire Motherboard Replacement: passo 9, immagine 3 di 3
    • Use a plastic opening tool to lift up and disconnect the display data cable.
    • Lift up on the antenna connector with a plastic opening tool to disconnect it.
    • De-route the antenna cable.
    Be very careful when disconnecting the antenna, and be sure to note how the cable is routed into the little socket on the motherboard. The reconnecting of the antenna cable into its motherboard port can be tricky and will require patience, persistence and perhaps a magnifier and tweezers.
    Jeff Jones - Replica
    note that the image still displays the speakers that were supposed to be removed in an earlier step
    diprosew - Replica
    Followed the steps but once reassembled the screen comes on but doesn't respond to touch. It was working fine even with broken glass screen. Any suggestions?
    John Moore - Replica
    Mine is doing the same thing! What did you do to fix it?
    Tara -
    I order a replacement motherboard from ifixit and for some reason it had a plastic increasing around the outer edge of the "display data cable connection port" on the motherboard, which makes it impossible to connect the cable to the motherboard. I called ifixit and they said send a picture and a description. Hopefully the customer who owns the kindle fire will understand that after waiting on the part for a week. :\
    nuban1990 - Replica
    Mine no longer responded to touch!!!!! Why did we all have the same problem on reassembly after changing charging port?
    gregk8776 - Replica
  10. Kindle Fire Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the six 2.6 mm Phillips #00 screws securing the motherboard to the frame.
  11. Kindle Fire Motherboard Replacement: passo 11, immagine 1 di 3 Kindle Fire Motherboard Replacement: passo 11, immagine 2 di 3 Kindle Fire Motherboard Replacement: passo 11, immagine 3 di 3
    • Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
    • Lever the top side of the motherboard up with a plastic opening tool until it comes free.
    • Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
Conclusione
Altre 64 persone hanno completato questa guida.
Jake Devincenzi
Membro da: 04/18/11
117.301 Reputazione
57 Guide realizzate
5 Commenti
These are excellent instructions. Unfortunately, it's impossible to find a motherboard for a first generation Kindle KINDLE FIRE 31KC1MB0090 for the D01400. I just spent an hour searching the Internet including, eBay, powerbookmedic.com and Pronto.com. PowerBookmedic advertises the motherboard but they are out of stock. If anyone has any sources, I would greatly appreciated it.
pcanady1998 - Replica
I did it! I removed the Kindle Fire 7" motherboard, replaced the USB connector with one bought from a vendor on eBay, and then reassembled the Kindle with a fully functional USB connector. Your guide made it an easy project for a couple hours on a Sunday afternoon.
Soldering the fine-pitched connector is probably not for the faint of heart, but I have a good temperature controlled soldering station and a lighted magnifier that made the task eminently do-able.
I would not have tackled this project without your step-by-step guide and Plastic Opening Tools.
Thanks!
/john
jkeefe1 - Replica
Where did you get the connector. If you can send me a link for the connector. I have the same issue.
Kevin
rkevinball -
Mon kindle fire ne s'allume pas car lorsqu'il affiche le logo directement un écran rouge affiche et puis rien
NICEFORT - Replica
I didn’t rip the sensor ribbon but the touch screen isnt working. It’s all connected as should be
zodiemichelle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 89
Tutti i Tempi: 150,231
