Salta al contenuto principale
Kindle Fire LCD Replacement
Cosa ti serve
  1. Kindle Fire LCD Replacement, Back Case: passo 1, immagine 1 di 3 Kindle Fire LCD Replacement, Back Case: passo 1, immagine 2 di 3 Kindle Fire LCD Replacement, Back Case: passo 1, immagine 3 di 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
  2. Kindle Fire LCD Replacement: passo 2, immagine 1 di 1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
  3. Kindle Fire LCD Replacement, Battery: passo 3, immagine 1 di 3 Kindle Fire LCD Replacement, Battery: passo 3, immagine 2 di 3 Kindle Fire LCD Replacement, Battery: passo 3, immagine 3 di 3
    • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
    • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  4. Kindle Fire LCD Replacement: passo 4, immagine 1 di 1
    • Repeat the process from the previous step to free the left battery cell.
  5. Kindle Fire LCD Replacement: passo 5, immagine 1 di 2 Kindle Fire LCD Replacement: passo 5, immagine 2 di 2
    • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
    • Pull the battery out of the Kindle Fire.
  6. Kindle Fire LCD Replacement, Speaker Assembly: passo 6, immagine 1 di 3 Kindle Fire LCD Replacement, Speaker Assembly: passo 6, immagine 2 di 3 Kindle Fire LCD Replacement, Speaker Assembly: passo 6, immagine 3 di 3
    • Peel the tape on the upper-left IC that is securing the speaker cable.
    • Use the flat end of a spudger to push the speaker connector out of its socket.
    • Deroute the speaker cable.
  7. Kindle Fire LCD Replacement: passo 7, immagine 1 di 2 Kindle Fire LCD Replacement: passo 7, immagine 2 di 2
    • Remove the two 3.3 mm Phillips #00 screws securing the speakers to the Kindle Fire.
    • Lift the speakers out of the Kindle Fire.
  8. Kindle Fire LCD Replacement, Motherboard: passo 8, immagine 1 di 3 Kindle Fire LCD Replacement, Motherboard: passo 8, immagine 2 di 3 Kindle Fire LCD Replacement, Motherboard: passo 8, immagine 3 di 3
    • Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
    • Use a plastic opening tool to release the touchscreen controller connector.
    • Gently remove the touchscreen controller by lifting it up and to the right.
    • Be careful not to rip the ribbon cable in doing so.
  9. Kindle Fire LCD Replacement: passo 9, immagine 1 di 3 Kindle Fire LCD Replacement: passo 9, immagine 2 di 3 Kindle Fire LCD Replacement: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a plastic opening tool to flip open the power button ZIF connector.
    • This connector will not be removed until the motherboard is free.
    • Flip open the ambient light sensor ZIF socket with a plastic opening tool.
    • Use a pair of tweezers to pull the blue tab on the ambient light sensor cable to remove it from its socket.
  10. Kindle Fire LCD Replacement: passo 10, immagine 1 di 3 Kindle Fire LCD Replacement: passo 10, immagine 2 di 3 Kindle Fire LCD Replacement: passo 10, immagine 3 di 3
    • Use a plastic opening tool to lift up and disconnect the display data cable.
    • Lift up on the antenna connector with a plastic opening tool to disconnect it.
    • De-route the antenna cable.
  11. Kindle Fire LCD Replacement: passo 11, immagine 1 di 1
    • Remove the six 2.6 mm Phillips #00 screws securing the motherboard to the frame.
  12. Kindle Fire LCD Replacement: passo 12, immagine 1 di 3 Kindle Fire LCD Replacement: passo 12, immagine 2 di 3 Kindle Fire LCD Replacement: passo 12, immagine 3 di 3
    • Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
    • Lever the top side of the motherboard up with a plastic opening tool until it comes free.
    • Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
  13. Kindle Fire LCD Replacement, Power Button Board: passo 13, immagine 1 di 2 Kindle Fire LCD Replacement, Power Button Board: passo 13, immagine 2 di 2
    • Remove the 2.5 mm Phillips #00 scew securing the power button board to the Kindle Fire.
    • Lift the power button board out of the Kindle Fire.
  14. Kindle Fire LCD Replacement, Frame Loosening: passo 14, immagine 1 di 3 Kindle Fire LCD Replacement, Frame Loosening: passo 14, immagine 2 di 3 Kindle Fire LCD Replacement, Frame Loosening: passo 14, immagine 3 di 3
    • Use the flat end of a spudger to peel the ambient light sensor cable off of the frame.
    • You will need to peel up the silver tape in the cable's lower right bend. The silver tape under the lower left bend of the cable does not need to come up with it.
  15. Kindle Fire LCD Replacement: passo 15, immagine 1 di 1
    • Use the flat end of a spudger to peel up the silver tape securing the antenna cable.
  16. Kindle Fire LCD Replacement: passo 16, immagine 1 di 1
    • Remove the five 3.6 mm Phillips #00 screws securing the frame and ambient light sensor.
  17. Kindle Fire LCD Replacement, Ambient Light Sensor: passo 17, immagine 1 di 1
    • Slide the ambient light sensor out from under the frame and remove it from the Kindle Fire.
    • If the ambient light sensor will not easily come out, slightly lift the frame with a plastic opening tool to allow it to come free.
  18. Kindle Fire LCD Replacement, Frame: passo 18, immagine 1 di 3 Kindle Fire LCD Replacement, Frame: passo 18, immagine 2 di 3 Kindle Fire LCD Replacement, Frame: passo 18, immagine 3 di 3
    • Use the flat end of a spudger to lever the frame away from the display assembly until you can grab it with your hand.
    • Lift near the retaining tabs marked by red rectangles in the first picture.
    • Remove the frame from the display assembly.
    • While removing the frame there may be sticky residue that will generate some resistance to the detachment of the top half of the frame.
  19. Kindle Fire LCD Replacement, LCD: passo 19, immagine 1 di 3 Kindle Fire LCD Replacement, LCD: passo 19, immagine 2 di 3 Kindle Fire LCD Replacement, LCD: passo 19, immagine 3 di 3
    • Remove the four 2.4 mm Phillips #00 screws attaching the LCD to the front glass panel.
    • Rotate the top of the LCD 90 degrees away from the front glass panel as shown in the second picture.
    • Rotate the LCD and front glass panel slowly so you don't damage the antenna on the bottom of the LCD.
    • Separate the LCD and front glass panel.
Conclusione
Altre 22 persone hanno completato questa guida.
Phillip Takahashi
Membro da: 08/22/11
87.618 Reputazione
87 Guide realizzate
2Commenti sulla guida
Is the LCD the same thing as the digitizer? My touch screen is really glitchy and I did a hard reset and a factory reset and I’m still having trouble. I’m trying to decide what I need to replace?
Jesse McCallister - Replica
No, the digitizer is the glass itself. The only thing the lcd does is display things.
notadingo -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 125
Tutti i Tempi: 42,701
