Introduzione
Use this guide to replace the metal midframe on the interior of the Kindle Fire HD 8.9". Removing this metal casing is a prerequisite for replacing most of the Kindle Fire HD's internal components.
Cosa ti serve
Remove the SIM card tray (if present in your model).
Insert a large plastic opening tool next to the Kindle's headphone jack.
Move the plastic opening tool evenly around the Kindle, separating the two halves.
Remove the following sixteen screws from the metal midframe on the rear of the device:
One 3 mm Phillips screw from each corner
Four 3 mm Phillips screws surrounding the ports
Eight 3 mm Phillips screws from the body of the midframe
2 Commenti
I suggest not removing the cables (steps 3,4 and 5) because it seems impossible to reconnect them.
Those are ZIF connectors—flip up the locking tab to release the cable, and you can remove/reinsert it freely.
