Introduzione
Use this guide to remove the battery from the back of the Kindle Fire HD 8.9".
Remove the SIM card tray (if present in your model).
Insert a large plastic opening tool next to the Kindle's headphone jack.
Move the plastic opening tool evenly around the Kindle, separating the two halves.
Lift the retaining flap on the ZIF connector of the upper flex cable.
Gently pull the cable out of its socket.
This is very delicate. The flap is very easy to break off. Remove the yellow tape on both these connectors and replace with ordinary plastic tape upon reassembly. If you don't tape them you'll pull them apart working on the other. A helper to hold the assy is a good idea.
Remove the following sixteen screws from the metal midframe on the rear of the device:
One 3 mm Phillips screw from each corner
Four 3 mm Phillips screws surrounding the ports
Eight 3 mm Phillips screws from the body of the midframe
Lift up on the silver ends of the black flex cable that lays across the battery.
Gently pull the black flex cable from the battery.
Starting at the outside edge of the battery, use the flat edge of a spudger to separate the battery from the rear of the device.
Move the spudger along each side of the battery, prying upwards with even pressure.
As the adhesive releases, push the spudger further underneath the battery.
Once half of the battery is detached, pry the other half in the same manner.
Remove the battery assembly from the Kindle.
Altre 17 persone hanno completato questa guida.
Getting the SIM card dummy plug out a real challenge. Broke off one end. Seems this part was never intended to be removed.
Bob Steger - Replica
