Salta al contenuto principale
Kindle 2 Battery Replacement
Cosa ti serve
  1. Kindle 2 Battery Replacement, Battery: passo 1, immagine 1 di 3 Kindle 2 Battery Replacement, Battery: passo 1, immagine 2 di 3 Kindle 2 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
    I had a heck of time using the spudger. I have found that grabbing the corners and using my thumbs to push the plastic away worked like a champ.
    teamhudson - Replica
    Thanks for this tip, was successful using the thumb method :)
    Rosie A. -
    to help get enough grip with my thumbs, I used a piece of old yoga mat to increase friction between thumbs and the top plastic piece
    Rosie A. -
    For anyone still looking for this in 2020, see my comment here for how to properly remove the back.
    Smontaggio Kindle 2
    Dave76 - Replica
  2. Kindle 2 Battery Replacement: passo 2, immagine 1 di 2 Kindle 2 Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
  3. Kindle 2 Battery Replacement: passo 3, immagine 1 di 2 Kindle 2 Battery Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
  4. Kindle 2 Battery Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
  5. Kindle 2 Battery Replacement: passo 5, immagine 1 di 2 Kindle 2 Battery Replacement: passo 5, immagine 2 di 2
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
Conclusione
Altre 39 persone hanno completato questa guida.
Cal Poly, Team 12-32, Amido Spring 2013 Membro di Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 Membri
14 Guide realizzate
9 Commenti
I followed this guide, without changes, and was able to successfully swap a battery on a Kindle DX. The DX is essentially a Kindle 2 with a larger screen.
Eric - Replica
Thanks, easy and went well!
Maybe you need a thinner spudger, TH?
Laz - Replica
Easy! Worked well with the tools described. Kudos for making this available, it gave my old Kindle a new breath of life!
stevenwaegenaer - Replica
Easiest replacement I've done. Thanks!
shockwav - Replica
An ebay-acquired battery fit perfectly, but failed to reboot the kindle or accept a charge.
the battery looks idential to the Kindale battery to an old analog voltmeter.
I conformed that the kindle terminals were receiving battery voltage.
The replacement guide was just fine, Back to the original battery, which is well past its best-by date!
Charles Kennedy - Replica
Hello,
Any advice on where to buy a battery online (shipping to Portugal)?
From what I read not all batteies are good, and besides from ebay etc, I don’t know any good shop for this kind of product.
Thank you
Pedro R. - Replica
I did this procedure with no problem. However, kindle still doesn’t work and has the same Critical Battery scene. I contacted Amazon and they advised I corrupted the software by installing new battery.
dirk - Replica
thanks, worked like a charm. I used a pocket knife blade to get the top plastic part off.
Jack - Replica
Thank you so much for the guide! I was able to get my wife’s first Kindle (her favorite) back up and running. Super easy thanks to your guide.
icabod5000 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 56
Ultimi 30 Giorni: 259
Tutti i Tempi: 34,993
