Introduzione
If you discover any issues such as quickly draining battery, freezing, overheating, or charging problems, this could indicate that you need to replace your battery. Through using this guide, you can learn the proper way to conduct a battery replacement for the Kindle 10.
Cosa ti serve
Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
Altre 2 persone hanno completato questa guida.
1Commento della guida
Do you have any replacements if we break the case ?
