Salta al contenuto principale
Kihno Kit Album Battery Replacement
Cosa ti serve
  1. Kihno Kit Album Battery Replacement, Battery: passo 1, immagine 1 di 2 Kihno Kit Album Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Insert a spudger into the gap and pull downwards, so the top lifts up.
  2. Kihno Kit Album Battery Replacement: passo 2, immagine 1 di 2 Kihno Kit Album Battery Replacement: passo 2, immagine 2 di 2
    • Pull out the wired component from the Kihno for better access.
    • Remove the old battery by pulling outward towards yourself, starting from the top.
  3. Kihno Kit Album Battery Replacement: passo 3, immagine 1 di 1
    • Grab your new battery and place it where the old one was.
    • Angle the battery to where it is underneath the golden flap.
    • Push the rest of the battery down.
  4. Kihno Kit Album Battery Replacement: passo 4, immagine 1 di 1
    • Place the wired components back into the Kihno.
    • Ensure the white button is sticking from the outside through its designated hole.
  5. Kihno Kit Album Battery Replacement: passo 5, immagine 1 di 1
    • Using your fingers, push the top back into the Kihno.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 72
Tutti i Tempi: 409
