Salta al contenuto principale
KidzLane Walkie-Talkie Press-to-speak button Replacement
Cosa ti serve
  1. KidzLane Walkie-Talkie Press-to-speak button Replacement, Press-to-speak button: passo 1, immagine 1 di 1
    • Place the Walkie-Talkie on a flat surface-preferably a table or a desk.
    • Flip the device over to where you see four screws in each corner.
    • Make sure you take out the batteries before proceeding.
  2. KidzLane Walkie-Talkie Press-to-speak button Replacement: passo 2, immagine 1 di 2 KidzLane Walkie-Talkie Press-to-speak button Replacement: passo 2, immagine 2 di 2
    • Using your Phillips head screwdriver, unscrew all four 4mm screws from each corner.
  3. KidzLane Walkie-Talkie Press-to-speak button Replacement: passo 3, immagine 1 di 1
    • Once you have unscrewed all four corners, open the device so it will be in two parts.
    • As you're opening the inside of the Walkie-Talkie, don't break off any wires within the device.
    • Taking the Phillips head screwdriver again, unscrew the three screws on the circuit board (green plate).
    • Separate these screws from the other four since they are different sizes.
  4. KidzLane Walkie-Talkie Press-to-speak button Replacement: passo 4, immagine 1 di 2 KidzLane Walkie-Talkie Press-to-speak button Replacement: passo 4, immagine 2 di 2
    • Take the circuit board out of the plastic casing.
    • Use the soldering device to iron the silver box (press-to-speak button), and then remove it from the circuit board.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Amin
Membro da: 02/13/16
630 Reputazione
5 Guide realizzate
IUPUI, Team 1-1, Wilson Spring 2016 Membro di IUPUI, Team 1-1, Wilson Spring 2016
IUPUI-WILSON-S16S1G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 779
