Salta al contenuto principale
Kids Digital Watch Battery Replacement
Cosa ti serve
  1. Kids Digital Watch Battery Replacement, Remove Watch Bands: passo 1, immagine 1 di 2 Kids Digital Watch Battery Replacement, Remove Watch Bands: passo 1, immagine 2 di 2
    • Using a twisting and pulling motion, remove the straps from the watch.
  2. Kids Digital Watch Battery Replacement, Unscrew Backplate: passo 2, immagine 1 di 1
    • Remove the four (4) screws on the backside of the watch with the small Philips head screwdriver.
  3. Kids Digital Watch Battery Replacement, Remove Backplate: passo 3, immagine 1 di 1
    • Remove the backplate carefully using your hands.
  4. Kids Digital Watch Battery Replacement, Remove Circuit Protector Plate: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove using tweezers the circuit protector plate that is uncovered once the backplate is removed.
  5. Kids Digital Watch Battery Replacement, Removing Screw Near the Blue Component: passo 5, immagine 1 di 2 Kids Digital Watch Battery Replacement, Removing Screw Near the Blue Component: passo 5, immagine 2 di 2
    • With the tiny Philips head screwdriver, unscrew and remove the screw closest to the blue component.
  6. Kids Digital Watch Battery Replacement, Removing Screw Near the Yellow Component: passo 6, immagine 1 di 1
    • Now remove the screw on the other side of the battery near the yellow circuit component.
  7. Kids Digital Watch Battery Replacement, Remove the Battery Protector Plate: passo 7, immagine 1 di 2 Kids Digital Watch Battery Replacement, Remove the Battery Protector Plate: passo 7, immagine 2 di 2
    • Using tweezers carefully remove the battery protector plate.
  8. Kids Digital Watch Battery Replacement, Remove Battery: passo 8, immagine 1 di 1
    • Remove the old battery from your watch.
  9. Kids Digital Watch Battery Replacement, Insert New Battery: passo 9, immagine 1 di 1
    • Insert your new battery onto the circular component with your tweezers.
    • Ensure the positive and negative sides of your battery are oriented correctly.
Conclusione
Amelia S
Membro da: 03/14/23
194 Reputazione
1 Guida realizzata
ENGR_COMM_FIXERS Membro di ENGR_COMM_FIXERS
Community
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 66
Tutti i Tempi: 712
