Salta al contenuto principale
Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement
Cosa ti serve
  1. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement, Batteries: passo 1, immagine 1 di 1
    • Turn the controller over to the backside and locate the battery cover screw.
  2. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 2, immagine 1 di 1
    • The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
  3. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 3, immagine 1 di 1
    • Once the screw is removed lift the battery cover up from the controller.
  4. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 4, immagine 1 di 1
    • Remove the 2 AA batteries.
  5. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement, Internal Chip: passo 5, immagine 1 di 1
    • Remove both 6.0mm Phillips #1 screws holding the D-pads in place.
  6. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 6, immagine 1 di 1
    • Insert wisdom here.
  7. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 7, immagine 1 di 1
    • Remove the six 8.1 Phillips #1 screws.
  8. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 8, immagine 1 di 1
    • Lift the antenna holder away from the controller towards the top of the antenna.
  9. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 9, immagine 1 di 1
    • Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
    • Separate both halves of the controller.
  10. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 10, immagine 1 di 1
    • Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
  11. Kid Galaxy Morphibians Explorer Controller Internal Chip Replacement: passo 11, immagine 1 di 1
    • Remove the internal chip by pulling it away from the controller.
    • Remove both the positive(red wire) and negative(black wire) from the battery terminals.
    • Reverse the steps to put everything back together.
Conclusione
USF Tampa, Team 1-2, Hickman Fall 2014 Membro di USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 177
