Salta al contenuto principale
Kid Galaxy Morphibians Explorer Controller Battery Replacement
Cosa ti serve
  1. Kid Galaxy Morphibians Explorer Controller Battery Replacement, Batteries: passo 1, immagine 1 di 1
    • Turn the controller over to the backside and locate the battery cover screw.
  2. Kid Galaxy Morphibians Explorer Controller Battery Replacement: passo 2, immagine 1 di 1
    • The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
  3. Kid Galaxy Morphibians Explorer Controller Battery Replacement: passo 3, immagine 1 di 1
    • Once the screw is removed lift the battery cover up from the controller.
  4. Kid Galaxy Morphibians Explorer Controller Battery Replacement: passo 4, immagine 1 di 1
    • Remove the 2 AA batteries.
Conclusione
USF Tampa, Team 1-2, Hickman Fall 2014 Membro di USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 183
