Salta al contenuto principale
Kid Galaxy Morphibians Explorer Battery Replacement
Cosa ti serve
  1. Kid Galaxy Morphibians Explorer Battery Replacement, Battery: passo 1, immagine 1 di 1
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. Kid Galaxy Morphibians Explorer Battery Replacement: passo 2, immagine 1 di 1
    • After the screw has been loosened, lift the cover off.
  3. Kid Galaxy Morphibians Explorer Battery Replacement: passo 3, immagine 1 di 1
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. Kid Galaxy Morphibians Explorer Battery Replacement: passo 4, immagine 1 di 1
    • Lift the battery cover to gain access to the batteries.
    • Replace the 3 AA batteries and reverse the steps to put everything back together.
Conclusione
USF Tampa, Team 1-2, Hickman Fall 2014 Membro di USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,542
