Salta al contenuto principale
Kid Galaxy Morphibians Explorer Axle Replacement
Cosa ti serve
  1. Kid Galaxy Morphibians Explorer Axle Replacement, Axle: passo 1, immagine 1 di 1
    • Remove both 8.0 mm Phillips #1 screws, one for each wheel.
  2. Kid Galaxy Morphibians Explorer Axle Replacement: passo 2, immagine 1 di 1
    • Remove the wheels by pulling them away from the RC car.
  3. Kid Galaxy Morphibians Explorer Axle Replacement: passo 3, immagine 1 di 1
    • Make note of where each driving gear cover is placed. They only go in one way.
    • Remove the eight 8.0mm Phillips #00 screws, two screws for each wheel.
  4. Kid Galaxy Morphibians Explorer Axle Replacement: passo 4, immagine 1 di 1
    • Pry open the two gear covers on both sides.
  5. Kid Galaxy Morphibians Explorer Axle Replacement: passo 5, immagine 1 di 1
    • Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
  6. Kid Galaxy Morphibians Explorer Axle Replacement: passo 6, immagine 1 di 1
    • Slide both axles from the internal axles guides within the car.
    • Reverse the steps to replace the axles.
Conclusione
USF Tampa, Team 1-2, Hickman Fall 2014 Membro di USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 292
