Introduzione
Regular usage of this device may cause the K-cup holder to clog or accidentally crack. This guide will show you how to remove a K-cup holder for either cleaning or replacement for your Keurig Mini B-31.
Strumenti
Parti
Nessuna parte richiesta.
  1. Lift up the handle of the Keurig Mini.
    • Lift up the handle of the Keurig Mini.
  2. Make sure to avoid the needles above and inside the K-cup because may puncture your hand Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier.  The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
    • Make sure to avoid the needles above and inside the K-cup because may puncture your hand
    • Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat. Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
    • Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
  5. Pull the K-cup holder straight out.
    • Pull the K-cup holder straight out.
Conclusione
Altre 5 persone hanno completato questa guida.
Andrew Adriance
Membro da: 14/01/2014
1.634 Reputazione
7 Guide realizzate
Cal Poly, Team 17-1, Forte Winter 2014 Membro di Cal Poly, Team 17-1, Forte Winter 2014
CPSU-FORTE-W14S17G1
5 Membri
12 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 36
Tutti i Tempi: 8,421
