Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Replacing a Keurig water filter will help your machine run smoother. This also helps improve the quality of brews.
Strumenti
Nessun attrezzo specificato.
  1. Soak the new charcoal filter in water for 5 minutes.
    • Soak the new charcoal filter in water for 5 minutes.
  2. Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away. Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away. Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away.
    • Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away.
  3. Remove the lid from the water reservoir and empty any remaining water from the tank.
    • Remove the lid from the water reservoir and empty any remaining water from the tank.
  4. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove water filter holder from within the water reservoir by pulling up on the holder and lifting it out. Remove water filter holder from within the water reservoir by pulling up on the holder and lifting it out.
    • Remove water filter holder from within the water reservoir by pulling up on the holder and lifting it out.
  6. To remove the old filter, pinch both sides of the filter holder at the base and pull it apart.  Remove the old filter by lifting it out of the filter holder. Dispose of old water filter cartridge.
    • To remove the old filter, pinch both sides of the filter holder at the base and pull it apart. Remove the old filter by lifting it out of the filter holder.
    • Dispose of old water filter cartridge.
  7. Take the soaked water filter and rinse it under running water for 60 seconds.
    • Take the soaked water filter and rinse it under running water for 60 seconds.
  8. Place new water filter cartridge into the upper filter holder. Snap the  bottom of the filter holder back on by aligning the tabs with the spaces
    • Place new water filter cartridge into the upper filter holder.
    • Snap the bottom of the filter holder back on by aligning the tabs with the spaces
Conclusione
Maria Kostourkova
Membro da: 20/06/2018
145 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 274
