Introduzione
Removal and replacement of the Keurig K55 water filter.
Parti
Nessuna parte richiesta.
  1. Grab the lid of the water reservoir on the left side of the Keurig. Lift up to remove the water reservoir lid. Lift up to remove the water reservoir lid.
    • Grab the lid of the water reservoir on the left side of the Keurig.
    • Lift up to remove the water reservoir lid.
  2. Grab the water filter on the inside of the reservoir. Remove filter by pulling straight up.
    • Grab the water filter on the inside of the reservoir.
    • Remove filter by pulling straight up.
    • Pulling the filter out may require a bit of effort.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Pinch both sides of end cap on the large end of the filter. With both tabs compressed, pull the cap off of the housing. With both tabs compressed, pull the cap off of the housing.
    • Pinch both sides of end cap on the large end of the filter.
    • With both tabs compressed, pull the cap off of the housing.
  5. Remove exposed filter. Remove exposed filter.
    • Remove exposed filter.
Conclusione
William O'Brien
Membro da: 23/01/2018
473 Reputazione
4 Guide realizzate
Cal Poly, Team S1-G3, Livingston Winter 2018 Membro di Cal Poly, Team S1-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G3
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 104
Tutti i Tempi: 1,422
