Salta al contenuto principale
Keurig K40 Top Water Pump Replacement
Cosa ti serve
  1. Keurig K40 Top Water Pump Replacement, Top Water Pump: passo 1, immagine 1 di 1
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Top Water Pump Replacement: passo 2, immagine 1 di 1
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Top Water Pump Replacement: passo 3, immagine 1 di 2 Keurig K40 Top Water Pump Replacement: passo 3, immagine 2 di 2
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Top Water Pump Replacement: passo 4, immagine 1 di 2 Keurig K40 Top Water Pump Replacement: passo 4, immagine 2 di 2
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 6-1, Eyestone Spring 2016 Membro di USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Membri
5 Guide realizzate
4 Commenti
I NEED ONE OF THESE! Where can I find one????
G Steve - Replica
This is a check valve, not the water pump.
Rick Koen - Replica
Please rename this article. The item is not a water pump.
tvyse46 - Replica
I viewed this to replace the pump. But after the checkvalve was replaced through these instructions my K40 works like new. Thank you.
Glenn Stanley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 52
Tutti i Tempi: 9,422
