Salta al contenuto principale
Keurig K40 Spring Replacement
Cosa ti serve
  1. Keurig K40 Spring  Replacement, Spring: passo 1, immagine 1 di 2 Keurig K40 Spring  Replacement, Spring: passo 1, immagine 2 di 2
    • Using a Phillips #2 screwdriver unscrew two 2mm screws.
    • Once the screws are out, lift up and squeeze the k-cup assembly housing to take it out.
  2. Keurig K40 Spring  Replacement: passo 2, immagine 1 di 1
    • Use the handle to open the lid then squeeze and move the lid around to take it off.
  3. Keurig K40 Spring  Replacement: passo 3, immagine 1 di 3 Keurig K40 Spring  Replacement: passo 3, immagine 2 di 3 Keurig K40 Spring  Replacement: passo 3, immagine 3 di 3
    • Using the Phillips #0 screwdriver unscrew two 2mm screws on the water pump.
    • Once unscrewed lift the water pump up and pull and twist it off.
  4. Keurig K40 Spring  Replacement: passo 4, immagine 1 di 2 Keurig K40 Spring  Replacement: passo 4, immagine 2 di 2
    • Using the tweezer and the plastic opening tool grab the front of the spring to take it off.
Conclusione
USF Tampa, Team 6-1, Eyestone Spring 2016 Membro di USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 26
Tutti i Tempi: 4,515
