Salta al contenuto principale
Keurig K40 Open/Close Sensor Replacement
Cosa ti serve
  1. Keurig K40 Open/Close Sensor Replacement, Top Water Pump: passo 1, immagine 1 di 1
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Open/Close Sensor Replacement: passo 2, immagine 1 di 1
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Open/Close Sensor Replacement: passo 3, immagine 1 di 2 Keurig K40 Open/Close Sensor Replacement: passo 3, immagine 2 di 2
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Open/Close Sensor Replacement: passo 4, immagine 1 di 2 Keurig K40 Open/Close Sensor Replacement: passo 4, immagine 2 di 2
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
  5. Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: passo 5, immagine 1 di 2 Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: passo 5, immagine 2 di 2
    • Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
    • Locate where the connections are soldered to the sensor
  6. Keurig K40 Open/Close Sensor Replacement: passo 6, immagine 1 di 1
    • Melt the solder that is connected to the sensor.
    • Be careful to avoid any rubber and try to only contact the metal making the connection.
  7. Keurig K40 Open/Close Sensor Replacement: passo 7, immagine 1 di 1
    • Put the replacement sensor back on the post that holds it and begin to solder the two metal connections back to the sensor.
    • Be careful not to touch the end of the soldering iron.
Conclusione
jonathan
Membro da: 02/08/16
738 Reputazione
2 Guide realizzate
USF Tampa, Team 6-1, Eyestone Spring 2016 Membro di USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Membri
5 Guide realizzate
Un commento
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
John Fictum - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,760
