Salta al contenuto principale
Keurig K40 Handle Replacement
Cosa ti serve
  1. Keurig K40 Handle Replacement, Handle: passo 1, immagine 1 di 1
    • Unscrew one of the 2mm screws on the handle using a T15 screw head. Keep a firm grip on the device so it does not shift out of place.
  2. Keurig K40 Handle Replacement: passo 2, immagine 1 di 1
    • Flip the Keurig over and unscrew the other 2mm screw using the same screw head. Keep a firm grip on the device to prevent it from shifting or falling.
  3. Keurig K40 Handle Replacement: passo 3, immagine 1 di 1
    • Remove the lever by pulling it away from the Keurig.
    • Replace a new handle by putting the Keurig back together the same way it was taken apart.
Conclusione
USF Tampa, Team 6-1, Eyestone Spring 2016 Membro di USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,084
