Salta al contenuto principale
Keurig K10 Mini Plus Cup Holder Replacement
Cosa ti serve
  1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: passo 1, immagine 1 di 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: passo 1, immagine 2 di 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: passo 1, immagine 3 di 3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 Mini Plus Cup Holder Replacement: passo 2, immagine 1 di 2 Keurig K10 Mini Plus Cup Holder Replacement: passo 2, immagine 2 di 2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Conclusione
Mark Henein
Membro da: 02/04/16
369 Reputazione
2 Guide realizzate
USF Tampa, Team 17-6, Blackwell Winter 2016 Membro di USF Tampa, Team 17-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G6
2 Membri
2 Guide realizzate
Un commento
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
Marie - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,464
