Introduzione
Replacing the dispenser head for the Keurig K10 Mini Plus is a good step for the beginner who wishes to gain some more experience in lengthier replacements. While the steps are simple, they have a moderate amount of time involvement needed.
Cosa ti serve
Lift the cold water reserve lid up to reveal its hinge.
Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
Remove two 9 mm Phillips #1 screws.
The screws are located on the top of where the K-Cup would be.
Remove two 14 mm Phillips #2 screws.
Remove two 12 mm Phillips #2 screws.
Lift the arm off the assembly. This will reveal the tank hole as shown.
Pull the head assembly forward to reveal the two plastic axle points that keep the head assembly attached to the base.
