Salta al contenuto principale
Kenwood KDC-BT565U Fuse Replacement
Cosa ti serve
  1. Kenwood KDC-BT565U Fuse Replacement, Fuse: passo 1, immagine 1 di 1
    • The fuse can be found on the back of your radio indicated by the red square in the photo.
  2. Kenwood KDC-BT565U Fuse Replacement: passo 2, immagine 1 di 2 Kenwood KDC-BT565U Fuse Replacement: passo 2, immagine 2 di 2
    • Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
    • Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
Conclusione
To reassemble, follow these instructions in reverse order.
Altre 4 persone hanno completato questa guida.
Darren Evans
Membro da: 02/15/17
273 Reputazione
2 Guide realizzate
USF Tampa, Team S2-G5, Lacy Spring 2017 Membro di USF Tampa, Team S2-G5, Lacy Spring 2017
USFT-LACY-S17S2G5
4 Membri
11 Guide realizzate
7 Commenti
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
jasonfisher036@gmail.com - Replica
it does not explain how to pull the reciever out.
d_lalande - Replica
same problem, how to remove the receiver
Jason Armondo - Replica
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Javier Castellanos - Replica
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Jannie watkins -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 204
Tutti i Tempi: 21,392
