Salta al contenuto principale
Kenwood DRV-N520 Dashcam Motherboard Replacement
Cosa ti serve
  1. Kenwood DRV-N520 Dashcam Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the device backing.
    • Remove the back cover.
  2. Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the four 3mm screws in the copper plate using a Phillips #0 screwdriver.
    • Remove the copper plate to gain access to the motherboard.
  3. Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 3, immagine 1 di 2 Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the ribbon cable by gently pulling on it while using a spudger to apply pressure to the lever (orange arrow) holding it in place.
  4. Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 4, immagine 1 di 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 4, immagine 2 di 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: passo 4, immagine 3 di 3
    • Disconnect the speaker connection from the circuit board by using your fingers to apply pressure to the clip holding it in place.
    • Finally, remove the two screws from the two corners of the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard from the device.
Conclusione
This will conclude the removal of the circuit card. Please refer to the troubleshooting guide for any question.
Un commento
I have a fault with the G FORCE sensor on my device. Any advise on how to deactivate or remove the sensor.
tomle3 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 182
