Salta al contenuto principale
Kenwood DNX571HD GPS Antenna Connection Replacement
Cosa ti serve
  1. Kenwood DNX571HD GPS Antenna Connection Replacement, CD/DVD Drive: passo 1, immagine 1 di 2 Kenwood DNX571HD GPS Antenna Connection Replacement, CD/DVD Drive: passo 1, immagine 2 di 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 2, immagine 1 di 3 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 2, immagine 2 di 3 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 2, immagine 3 di 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 3, immagine 1 di 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 4, immagine 1 di 3 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 4, immagine 2 di 3 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 4, immagine 3 di 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 5, immagine 1 di 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 6, immagine 1 di 2 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 6, immagine 2 di 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
  7. Kenwood DNX571HD GPS Antenna Connection Replacement, Cooling Fan: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Carefully unplug the fan power cord with the tweezers.
  8. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 8, immagine 1 di 2 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 8, immagine 2 di 2
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
  9. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 9, immagine 1 di 2 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 9, immagine 2 di 2
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
  10. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 10, immagine 1 di 3 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 10, immagine 2 di 3 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 10, immagine 3 di 3
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
  11. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 11, immagine 1 di 1
    • Lift the top part of the unit up from the lower chassis.
  12. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 12, immagine 1 di 2 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 12, immagine 2 di 2
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
  13. Kenwood DNX571HD GPS Antenna Connection Replacement, GPS Antenna Connection: passo 13, immagine 1 di 2 Kenwood DNX571HD GPS Antenna Connection Replacement, GPS Antenna Connection: passo 13, immagine 2 di 2
    • Using a spudger, undo the clasp to disconnect the large white ribbon cable.
  14. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 14, immagine 1 di 1
    • Remove the 5mm screw with teeth from the casing with a Phillips #1 screwdriver.
  15. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 15, immagine 1 di 1
    • Remove the four 5mm screws with a Phillips #1 screwdriver.
  16. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 16, immagine 1 di 2 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 16, immagine 2 di 2
    • Remove the 5.5mm screw from the HDMI cable cover using a Phillips #2 screwdriver.
  17. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 17, immagine 1 di 1
    • Remove the 5mm screw with a Phillips #1 screwdriver.
  18. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 18, immagine 1 di 2 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 18, immagine 2 di 2
    • Remove the two 5.5mm screws from the back.
    • Lift the upper portion of the stereo free from the chassis.
  19. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 19, immagine 1 di 2 Kenwood DNX571HD GPS Antenna Connection Replacement: passo 19, immagine 2 di 2
    • Remove the two screws underneath the GPS connector.
    • Desolder the GPS connector.
    • The GPS antenna is a thru-hole-mounted device. You must apply heat to each soldered pin individually and pull them out of the holes while the solder is molten.
    • The solder material, pins, and any surrounding material will get VERY hot while melting the connections. Do not touch any metal parts during the desoldering process and give the device time to cool off once you’re finished. It may also be good to take breaks so that the electronics aren’t kept hot for extended periods of time.
  20. Kenwood DNX571HD GPS Antenna Connection Replacement: passo 20, immagine 1 di 1
    • To remove and reinsert the connector, on the top side of the board, use your finger to gently lift the metal plate to get enough clearance.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 855
