Salta al contenuto principale
Kenwood DNX571HD CD/DVD Drive Replacement
Cosa ti serve
  1. Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: passo 1, immagine 1 di 2 Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: passo 1, immagine 2 di 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD CD/DVD Drive Replacement: passo 2, immagine 1 di 3 Kenwood DNX571HD CD/DVD Drive Replacement: passo 2, immagine 2 di 3 Kenwood DNX571HD CD/DVD Drive Replacement: passo 2, immagine 3 di 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD CD/DVD Drive Replacement: passo 3, immagine 1 di 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD CD/DVD Drive Replacement: passo 4, immagine 1 di 3 Kenwood DNX571HD CD/DVD Drive Replacement: passo 4, immagine 2 di 3 Kenwood DNX571HD CD/DVD Drive Replacement: passo 4, immagine 3 di 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD CD/DVD Drive Replacement: passo 5, immagine 1 di 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD CD/DVD Drive Replacement: passo 6, immagine 1 di 2 Kenwood DNX571HD CD/DVD Drive Replacement: passo 6, immagine 2 di 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,073
