Salta al contenuto principale
Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad
  1. Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad, Speaker Cover: passo 1, immagine 1 di 3 Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad, Speaker Cover: passo 1, immagine 2 di 3 Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad, Speaker Cover: passo 1, immagine 3 di 3
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad: passo 2, immagine 1 di 3 Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad: passo 2, immagine 2 di 3 Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad: passo 2, immagine 3 di 3
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad: passo 3, immagine 1 di 3 Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad: passo 3, immagine 2 di 3 Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad: passo 3, immagine 3 di 3
    • Hold the speaker cover in one hand and the speaker ear-padding in the other.
    • Turn the speaker cover counter-clockwise until it stops turning.
    • Pull the speaker cover and the speaker ear padding apart to expose the inner components of the speaker.
    • Make sure to pull the speakers apart gently to avoid disconnecting the speaker cable wires from the speaker.
    • If the speaker cover and ear-padding don't easily come apart, then make sure the speaker cover is fully turned.
    • Repeat this process for both speakers.
  4. Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad, Speaker Ear-Pad: passo 4, immagine 1 di 3 Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad, Speaker Ear-Pad: passo 4, immagine 2 di 3 Kensington Hi-Fi Headphones 33137 Speaker Ear-Pad, Speaker Ear-Pad: passo 4, immagine 3 di 3
    • After the speaker cover has been removed, hold the edge of the speaker ear-pad with fingers.
    • Gently pull the edge of the speaker ear-pad around the edge of the speaker.
    • To avoid tearing the speaker ear-pad, don't use too much force when pulling it around the edge of the speaker.
    • Repeat this process for the other speaker ear-padding.
Conclusione
Clemson, Team 1-3, Benson Spring 2014 Membro di Clemson, Team 1-3, Benson Spring 2014
CLEM-BENSON-S14S1G3
3 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 895
