Introduzione
The headband on the Kensington Hi-Fi Headphones 33137 may occasionally become uncomfortable or worn and need replacement. This guide shows how to replace this component.
Cosa ti serve
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
Turn the headphones so that the inner tab of the speaker clamp where it attaches to the headband can be seen.
Pull the speaker clamp so that the metal lifts free of the headband.
Turn the headphones so that the metal pieces inside the headband covering can be seen.
Turn the headphones so that the metal part of the headband located inside the outer covering can be seen.
Un commento
Do you know how to make an adjustable headband for custom headphones? Please contact me!
Lisa Campbell
Owner Lit Headphones L.L.C.
LitHeadphones.com
MsLisaShawnitaCampbell@gmail.com
