Salta al contenuto principale
Kenmore 78423 Dustbin filter Replacement
  1. Kenmore 78423 Dustbin filter Replacement, Dust Bin: passo 1, immagine 1 di 2 Kenmore 78423 Dustbin filter Replacement, Dust Bin: passo 1, immagine 2 di 2
    • Grab the dustbin handle, press and hold the button at the top of the handle.
    • Pull the dustbin up and away from the main body.
  2. Kenmore 78423 Dustbin filter Replacement: passo 2, immagine 1 di 2 Kenmore 78423 Dustbin filter Replacement: passo 2, immagine 2 di 2
    • Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
    • Properly dispose any contents of the dust bin into a wastebasket.
  3. Kenmore 78423 Dustbin filter Replacement, Dustbin Filters: passo 3, immagine 1 di 3 Kenmore 78423 Dustbin filter Replacement, Dustbin Filters: passo 3, immagine 2 di 3 Kenmore 78423 Dustbin filter Replacement, Dustbin Filters: passo 3, immagine 3 di 3
    • Pinch and grasp the raised handle on the primary dustbin filter.
    • Lift the primary dustbin filter up and away from the dustbin and place it to the side.
  4. Kenmore 78423 Dustbin filter Replacement: passo 4, immagine 1 di 2 Kenmore 78423 Dustbin filter Replacement: passo 4, immagine 2 di 2
    • Grasp the foam filter and lift up to remove.
    • The foam filter may be lodged inside of the primary dustbin filter. In this case, both filters may be removed at the same time.
Conclusione
2 Commenti
What is the part number so I can purchase and replace dustbin filter
Bob Roper - Replica
Kenmore 78423 Dustbin Filters, where can I purchase new ones?
Bob Roper - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 859
