Salta al contenuto principale
Kenmore 78423 Dustbin fiber collector Replacement
  1. Kenmore 78423 Dustbin fiber collector Replacement, Dust Bin: passo 1, immagine 1 di 2 Kenmore 78423 Dustbin fiber collector Replacement, Dust Bin: passo 1, immagine 2 di 2
    • Grab the dustbin handle, press and hold the button at the top of the handle.
    • Pull the dustbin up and away from the main body.
  2. Kenmore 78423 Dustbin fiber collector Replacement: passo 2, immagine 1 di 2 Kenmore 78423 Dustbin fiber collector Replacement: passo 2, immagine 2 di 2
    • Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
    • Properly dispose any contents of the dust bin into a wastebasket.
  3. Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: passo 3, immagine 1 di 3 Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: passo 3, immagine 2 di 3 Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: passo 3, immagine 3 di 3
    • Grab the fiber collector using the finger holes on both sides of the base.
    • The fiber collector is the black basket with the rounded base
    • Turn the base a quarter-turn clockwise and pull it away from the dustbin
    • Remove the fiber and hair that may be stuck inside the fiber collector
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
thank you for your help. My sister in law didn’t have the manual, its typical of her husband. without the manual I probably would have broken the fiber collector. Appreciate your help.
joseph doyle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 489
