Salta al contenuto principale
Kenmore 73035 Water Filter Replacement
  1. Kenmore 73035 Water Filter Replacement, Water Filter: passo 1, immagine 1 di 3 Kenmore 73035 Water Filter Replacement, Water Filter: passo 1, immagine 2 di 3 Kenmore 73035 Water Filter Replacement, Water Filter: passo 1, immagine 3 di 3
    • Open the side of the refrigerator with the water filter.
    • Pull the water filter cover out.
    • The water filter cover will click when it is pulled out the required length.
    • Pull the water filter cover down.
  2. Kenmore 73035 Water Filter Replacement: passo 2, immagine 1 di 2 Kenmore 73035 Water Filter Replacement: passo 2, immagine 2 di 2
    • Turn the water filter 90 degrees counter clockwise.
  3. Kenmore 73035 Water Filter Replacement: passo 3, immagine 1 di 2 Kenmore 73035 Water Filter Replacement: passo 3, immagine 2 di 2
    • Remove the water filter.
    • You can not pull the water filter out unless it has been fully rotated counter clockwise.
  4. Kenmore 73035 Water Filter Replacement: passo 4, immagine 1 di 3 Kenmore 73035 Water Filter Replacement: passo 4, immagine 2 di 3 Kenmore 73035 Water Filter Replacement: passo 4, immagine 3 di 3
    • Wipe away any water that leaked during the removal of the water filter.
  5. Kenmore 73035 Water Filter Replacement: passo 5, immagine 1 di 2 Kenmore 73035 Water Filter Replacement: passo 5, immagine 2 di 2
    • Insert the new water filter.
  6. Kenmore 73035 Water Filter Replacement: passo 6, immagine 1 di 2 Kenmore 73035 Water Filter Replacement: passo 6, immagine 2 di 2
    • Turn the water filter 90 degrees clockwise to secure in place.
    • The water filter will not move when it is fully turned.
  7. Kenmore 73035 Water Filter Replacement: passo 7, immagine 1 di 3 Kenmore 73035 Water Filter Replacement: passo 7, immagine 2 di 3 Kenmore 73035 Water Filter Replacement: passo 7, immagine 3 di 3
    • Raise the water filter cover up.
    • Slide the water filter cover back into place.
    • The water filter cover will click when it is pushed in completely.
  8. Kenmore 73035 Water Filter Replacement: passo 8, immagine 1 di 2 Kenmore 73035 Water Filter Replacement: passo 8, immagine 2 di 2
    • Dispense water over the course of five minutes in cycles of 30 seconds ON and 60 seconds OFF.
    • Do not dispense water continuously for five minutes.
    • Completing this step will remove air from the water system and reduce fine particles from the new water filter.
  9. Kenmore 73035 Water Filter Replacement: passo 9, immagine 1 di 2 Kenmore 73035 Water Filter Replacement: passo 9, immagine 2 di 2
    • Press and hold the Accela Ice button icon for three seconds to turn the indicator light off.
    • Discard any ice produced within the first 24 hours.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
2 Commenti
It says filters are inexpensive. I don’t think $50 to $75 is inexpensive. In my opinion that’s price gouging.
Randy White - Replica
Press the button for several seconds to turn the indicator light off : it may extend the life of your filter. The manufacturer may have the cycle end earlier to have you buy more filters. That works with ink in copy machines. Water filters may be less forgiving.
w. gavin gilmor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 59
Tutti i Tempi: 2,457
