Salta al contenuto principale
Kenmore 110 Series Washing Machine Electronic Control Replacement
Cosa ti serve
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: passo 1, immagine 1 di 1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 2, immagine 1 di 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 2, immagine 2 di 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 2, immagine 3 di 3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 3, immagine 1 di 2 Kenmore 110 Series Washing Machine Electronic Control Replacement: passo 3, immagine 2 di 2
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
Conclusione
Altre 10 persone hanno completato questa guida.
Robert Trout
Membro da: 09/26/12
1.234 Reputazione
5 Guide realizzate
Cal Poly, Team 15-43, Forte Fall 2012 Membro di Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Membri
11 Guide realizzate
3 Commenti
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - Replica
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 183
Tutti i Tempi: 27,704
