Salta al contenuto principale
Kenmore 110 Series Washing Machine Drive Belt Replacement
Cosa ti serve
  1. Kenmore 110 Series Washing Machine Drive Belt Replacement, Drive Belt: passo 1, immagine 1 di 1
    • To avoid risk of electric shock, unplug the washing machine.
    • Lay the washing machine on its back.
  2. Kenmore 110 Series Washing Machine Drive Belt Replacement: passo 2, immagine 1 di 3 Kenmore 110 Series Washing Machine Drive Belt Replacement: passo 2, immagine 2 di 3 Kenmore 110 Series Washing Machine Drive Belt Replacement: passo 2, immagine 3 di 3
    • Using a 5/16" socket wrench, remove both screws from the belt cover.
    • Remove the belt cover from the washer.
  3. Kenmore 110 Series Washing Machine Drive Belt Replacement: passo 3, immagine 1 di 3 Kenmore 110 Series Washing Machine Drive Belt Replacement: passo 3, immagine 2 di 3 Kenmore 110 Series Washing Machine Drive Belt Replacement: passo 3, immagine 3 di 3
    • Using a 1/2" socket, remove the bolt securing the drive pulley.
    • Remove the drive pulley and belt.
    • When installing a new belt, wrap the belt around both the motor and drive pulleys before reinstalling the drive pulley.
Conclusione
Altre 18 persone hanno completato questa guida.
Robert Trout
Membro da: 09/26/12
1.234 Reputazione
5 Guide realizzate
Cal Poly, Team 15-43, Forte Fall 2012 Membro di Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Membri
12 Guide realizzate
9 Commenti
What would be reason that rinse cycle doesn't spin and it leaks
lauraleahenquinette - Replica
Will the drive belt make a clicking/grinding noise? I originally thought it was just a slipping noise, but empty it does make the grinding noise.
Gary Long Jr - Replica
It makes noise like it’s working but it’s not grabbing anything
Ricardo Vallegos - Replica
You can change your gearbox
Adarsh Pandey -
What belt type should I use for a 110.24642300? I cannot find its belt online.
Elizabeth Glenski - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 25
Ultimi 7 Giorni: 134
Ultimi 30 Giorni: 703
Tutti i Tempi: 128,183
