Salta al contenuto principale
Kazoo Diaphragm Replacement
Cosa ti serve
  1. Kazoo Diaphragm Replacement, Diaphragm: passo 1, immagine 1 di 1
    • Lay your kazoo down on a flat surface.
  2. Kazoo Diaphragm Replacement: passo 2, immagine 1 di 2 Kazoo Diaphragm Replacement: passo 2, immagine 2 di 2
    • Untwist the cap in the middle of the kazoo and set it to the side.
  3. Kazoo Diaphragm Replacement: passo 3, immagine 1 di 2 Kazoo Diaphragm Replacement: passo 3, immagine 2 di 2
    • Take the damaged diaphragm out with your fingers.
    • If you can't get the damaged diaphragm out with your fingers, turn the kazoo over and let the diaphragm fall out.
  4. Kazoo Diaphragm Replacement: passo 4, immagine 1 di 2 Kazoo Diaphragm Replacement: passo 4, immagine 2 di 2
    • Take a new diaphragm and place it back into the kazoo.
    • Twist the cap back on.
    • If you don't have any kazoo diaphragms, use scissors to cut a plastic wrapper or baking paper to the size of the hole and use that instead.
  5. Kazoo Diaphragm Replacement: passo 5, immagine 1 di 1
    • Take some paper towel and spray isopropyl alcohol on it to wipe off any dirt or dust.
  6. Kazoo Diaphragm Replacement: passo 6, immagine 1 di 1
    • Finally, let the kazoo dry off for 5 minutes, and it will sound new again. Happy playing!
Conclusione
Jose Meza
Membro da: 10/26/22
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 157
Tutti i Tempi: 3,508
