Salta al contenuto principale
Katadyne Hiker Water Filter Cleaning
Cosa ti serve
  1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: passo 1, immagine 1 di 1
    • Remove the "snap fit" guard by pulling directly away from the filter body.
  2. Katadyne Hiker Water Filter Cleaning: passo 2, immagine 1 di 1
    • Remove the pump handle by pulling it completely out of the shaft.
  3. Katadyne Hiker Water Filter Cleaning: passo 3, immagine 1 di 3 Katadyne Hiker Water Filter Cleaning: passo 3, immagine 2 di 3 Katadyne Hiker Water Filter Cleaning: passo 3, immagine 3 di 3
    • Use the pump handle to remove the filter cap.
    • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
    • Press the pump handle firmly against the fins and turn the filter counter clockwise.
    • Once unscrewed, remove the filter completely from the body.
  4. Katadyne Hiker Water Filter Cleaning: passo 4, immagine 1 di 3 Katadyne Hiker Water Filter Cleaning: passo 4, immagine 2 di 3 Katadyne Hiker Water Filter Cleaning: passo 4, immagine 3 di 3
    • Only perform this step if solid particles are evident on the outside of the filter.
    • Lightly brush the entire filter with a soft bristled toothbrush under running water.
  5. Katadyne Hiker Water Filter Cleaning: passo 5, immagine 1 di 1
    • Replace the filter inside the filter body and screw clockwise until tight.
  6. Katadyne Hiker Water Filter Cleaning: passo 6, immagine 1 di 1
    • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
  7. Katadyne Hiker Water Filter Cleaning: passo 7, immagine 1 di 1
    • Replace the pump handle inside the pump handle shaft.
  8. Katadyne Hiker Water Filter Cleaning: passo 8, immagine 1 di 2 Katadyne Hiker Water Filter Cleaning: passo 8, immagine 2 di 2
    • Replace the "snap-fit" guard by pushing directly toward the filter body.
Conclusione
If difficulty pumping persists, a new filter is required.
Dylan Carey
Membro da: 02/24/15
130 Reputazione
1 Guida realizzata
Cal Poly, Team 24-6, Green Winter 2015 Membro di Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Membri
15 Guide realizzate
Un commento
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 748
