Salta al contenuto principale
Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement
Cosa ti serve
  1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the tank: passo 1, immagine 1 di 2 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the tank: passo 1, immagine 2 di 2
    • Before you begin, make sure to power off and unplug the device.
    • Lift the tank by the handle and remove it from the device.
  2. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the transport wheels: passo 2, immagine 1 di 3 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the transport wheels: passo 2, immagine 2 di 3 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the transport wheels: passo 2, immagine 3 di 3
    • Press the yellow button near each wheel base to release the wheels.
    • Remove both wheels from their sockets.
  3. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump cover: passo 3, immagine 1 di 1
    • Use a T20 driver to remove the three screws securing the pump cover.
  4. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 4, immagine 1 di 3 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 4, immagine 2 di 3 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 4, immagine 3 di 3
    • Remove the pump cover.
  5. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Disconnect the pump: passo 5, immagine 1 di 2 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Disconnect the pump: passo 5, immagine 2 di 2
    • Squeeze the middle plug by the edges and pull it out of its socket.
    • During reassembly, make sure that all plugs are firmly seated in their sockets.
  6. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump bearings: passo 6, immagine 1 di 3 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump bearings: passo 6, immagine 2 di 3 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump bearings: passo 6, immagine 3 di 3
    • Lift the pump assembly out of its recess.
    • Reassembly tip: make sure that the output hose end is fully secured to the housing socket.
  7. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 7, immagine 1 di 3 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 7, immagine 2 di 3 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 7, immagine 3 di 3
    • Peel the two rubber bearings away from the pump.
  8. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 8, immagine 1 di 2 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 8, immagine 2 di 2
    • Feed the pump plug through the rubber bushing's cutout.
  9. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 9, immagine 1 di 2 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 9, immagine 2 di 2
    • Pull the black check valve off the pump's output port.
  10. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 10, immagine 1 di 2 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: passo 10, immagine 2 di 2
    • Pull the clear hose off the pump's input port.
  11. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump: passo 11, immagine 1 di 2 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump: passo 11, immagine 2 di 2
    • Remove the pump.
    • Reassembly tip: be careful not to mix the pump's input and output. The arrow points towards the pump output, which should connect to the black check valve.
Conclusione
Arthur Shi
Membro da: 01/03/18
282.051 Reputazione
585 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.426 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 644
