Introduzione
Use this guide to remove and replace the check valve on the underside of a Karcher Carpet Cleaner BRC3015C 2018.
Cosa ti serve
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Use a 3 mm hex key to remove two bolts securing the bottom cover.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Use a flathead screwdriver to loosen the hose clamps at each end of the check valve hose.
Pull the shorter hose straight off of the check valve to remove it.
Altre 2 persone hanno completato questa guida.
