Introduzione
Remove the bottom cover on a Karcher Carpet Cleaner BRC3015C 2018.
Cosa ti serve
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Use a 3 mm hex key to remove two bolts securing the bottom cover.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Altre 2 persone hanno completato questa guida.
