Salta al contenuto principale
Kano Computer Kit Complete Display Board Replacement
Cosa ti serve
  1. Kano Computer Kit Complete Display Board Replacement, Display Board: passo 1, immagine 1 di 2 Kano Computer Kit Complete Display Board Replacement, Display Board: passo 1, immagine 2 di 2
    • Take off the clear backing of the computer and set it aside.
    • The Display board is located in the top right corner of the case.
    Chiedi a FixBot
    Aggiungi Commento
  2. Kano Computer Kit Complete Display Board Replacement: passo 2, immagine 1 di 2 Kano Computer Kit Complete Display Board Replacement: passo 2, immagine 2 di 2
    • Always disconnect the battery before performing repairs.
    • Remove the power cable (Circled in red) from the board.
    Chiedi a FixBot
    Aggiungi Commento
  3. Kano Computer Kit Complete Display Board Replacement: passo 3, immagine 1 di 3 Kano Computer Kit Complete Display Board Replacement: passo 3, immagine 2 di 3 Kano Computer Kit Complete Display Board Replacement: passo 3, immagine 3 di 3
    • Unplug the HDMI cable (Circled in Yellow) from the board
    Chiedi a FixBot
    Aggiungi Commento
  4. Kano Computer Kit Complete Display Board Replacement: passo 4, immagine 1 di 1
    • Unscrew the four 8.5mm screws with your Phillips #1 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  5. Kano Computer Kit Complete Display Board Replacement: passo 5, immagine 1 di 2 Kano Computer Kit Complete Display Board Replacement: passo 5, immagine 2 di 2
    • Lift the board off the back of the screen.
    • Be gentle as there is a ribbon cable on the underside that will prevent the board from being removed completely.
    Chiedi a FixBot
    Aggiungi Commento
  6. Kano Computer Kit Complete Display Board Replacement: passo 6, immagine 1 di 2 Kano Computer Kit Complete Display Board Replacement: passo 6, immagine 2 di 2
    • Disconnect the white ribbon cable that you find underneath the board.
    • Be careful; it will take some force.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 39
Tutti i Tempi: 2,091
