Salta al contenuto principale
KYVOL CYBOVAC E20 Front Bumper Replacement
Cosa ti serve
  1. KYVOL CYBOVAC E20 Front Bumper Replacement, Front Bumper: passo 1, immagine 1 di 1
    • Start with the vacuum on a flat surface.
    • The power button should be on the side closest to you.
  2. KYVOL CYBOVAC E20 Front Bumper Replacement: passo 2, immagine 1 di 2 KYVOL CYBOVAC E20 Front Bumper Replacement: passo 2, immagine 2 di 2
    • Flip the vacuum over so the bottom is facing up.
    • The dust bin should be on the side furthest from you.
    • Remove the eight 1 mm screws holding the bumper in place using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Front Bumper Replacement: passo 3, immagine 1 di 2 KYVOL CYBOVAC E20 Front Bumper Replacement: passo 3, immagine 2 di 2
    • Remove both sides of the bumper and replace with new ones.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 236
