Introduzione
In this Fast Fix disassembly, we will teach you how to take apart your KRUPS milk foamer. Whether it is to fix a small problem or just out of curiosity, this guide will help you make a full disassembly using standard tools and making sure no parts are damaged in the process.
  1. Take off the plexiglass top. Remove the white milk spinner from the inside of the foamer.
    • Take off the plexiglass top.
    • Remove the white milk spinner from the inside of the foamer.
  2. Remove the 12mm Torx screws (x3) from the bottom of the foamer using a Torx TR10 screwdriver.
    • Remove the 12mm Torx screws (x3) from the bottom of the foamer using a Torx TR10 screwdriver.
  3. Open the bottom of the foamer.
    • Open the bottom of the foamer.
  4. Take out the grey and white power cables by pulling out the slide connectors from the base. Take out the grey and white power cables by pulling out the slide connectors from the base. Take out the grey and white power cables by pulling out the slide connectors from the base.
    • Take out the grey and white power cables by pulling out the slide connectors from the base.
  5. Remove the 16mm Torx screw in the middle of  the base using a Torx TR20 screwdriver. Take off the black bottom from the main body.
    • Remove the 16mm Torx screw in the middle of the base using a Torx TR20 screwdriver.
    • Take off the black bottom from the main body.
  6. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  7. Grab the power connector in the centre of the black bottom with a monkey wrench.
    • Grab the power connector in the centre of the black bottom with a monkey wrench.
    • Twist the connector clockwise to remove the center power socket.
  8. Remove the electromotor-plug using tweezers. Make sure to squeeze the small tab on the side of the plug to release it easily.
    • Remove the electromotor-plug using tweezers.
    • Make sure to squeeze the small tab on the side of the plug to release it easily.
  9. Remove the electromotor by hand. Remove the electromotor by hand.
    • Remove the electromotor by hand.
  10. Remove the rubber housing from the electromotor. Remove the small rubber cap from the other end of the electromotor.
    • Remove the rubber housing from the electromotor.
    • Remove the small rubber cap from the other end of the electromotor.
  11. Press on the two white clips to release the button case.
    • Press on the two white clips to release the button case.
    • Push one side out first to make it easier.
  12. Pull out the green ribbon cable through the rubber cover. Pull out the green ribbon cable through the rubber cover.
    • Pull out the green ribbon cable through the rubber cover.
  13. Pull off the rubber button caps from the button case.
    • Pull off the rubber button caps from the button case.
  14. Using tweezers, pull off the rubber cover from the base.
    • Using tweezers, pull off the rubber cover from the base.
    • Slide one side of the tweezers under the rubber to get a grip.
  15. Using your thumbs, push off the bottom plastic cover from the body. Make sure to push and rotate frequently. Pushing on multiple points around the edge of the part allows it to come off easier and without breaking. Due to this part being glued in, it takes some force to take it off.
    • Using your thumbs, push off the bottom plastic cover from the body.
    • Make sure to push and rotate frequently. Pushing on multiple points around the edge of the part allows it to come off easier and without breaking.
    • Due to this part being glued in, it takes some force to take it off.
  16. The product is now fully disassembled.
    • The product is now fully disassembled.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 312
