Introduzione
hi if you have a bad battery just remove the front-aluminum cover by prying it off then undo the torx screws and the light comes apart order the new battery , solder the old plug (from old battery) on to new battery , then screw front on replace aluminum cover and bob is your uncle fresh battery good light , one less landfill problem . the company refuses to provide despite the ease of fix and savings to the world in throwaways.
Cosa ti serve
Panoramica Video
Pry off the front-aluminum cover using a small slotted screwdriver
easily pulls apart battery connector in middle blue circle keep it you need to swap it for the one on the new battery as it is the correct one
batterry in back remove and resolder old connector on new battery replace and close
Altre 3 persone hanno completato questa guida.
4 Commenti
great work mate. Thanks for sharing this Knog tutorial.
Hi , I broke the plastic part on which the strape takes support to close the loop. Is there a possibility to change/repair it ?
Hi ! thank for your work + sharing. Could you tell me the reference / size / info of the battery to order it before opening !
What battery should I order?
Thanks.
