Salta al contenuto principale
KDDI Kyocera A5521K Speaker Replacement
Cosa ti serve
  1. KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: passo 1, immagine 1 di 3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: passo 1, immagine 2 di 3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Battery: passo 1, immagine 3 di 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. KDDI Kyocera A5521K Speaker Replacement: passo 2, immagine 1 di 3 KDDI Kyocera A5521K Speaker Replacement: passo 2, immagine 2 di 3 KDDI Kyocera A5521K Speaker Replacement: passo 2, immagine 3 di 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: passo 3, immagine 1 di 3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: passo 3, immagine 2 di 3 KDDI Kyocera A5521K Speaker Replacement, Disassembling KDDI Kyocera A5521K Faceplate: passo 3, immagine 3 di 3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. KDDI Kyocera A5521K Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the screws using a Y0 screwdriver.
  5. KDDI Kyocera A5521K Speaker Replacement: passo 5, immagine 1 di 3 KDDI Kyocera A5521K Speaker Replacement: passo 5, immagine 2 di 3 KDDI Kyocera A5521K Speaker Replacement: passo 5, immagine 3 di 3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. KDDI Kyocera A5521K Speaker Replacement: passo 6, immagine 1 di 1
    • Use the Y0 screwdriver to remove the screws.
  7. KDDI Kyocera A5521K Speaker Replacement: passo 7, immagine 1 di 2 KDDI Kyocera A5521K Speaker Replacement: passo 7, immagine 2 di 2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. KDDI Kyocera A5521K Speaker Replacement: passo 8, immagine 1 di 3 KDDI Kyocera A5521K Speaker Replacement: passo 8, immagine 2 di 3 KDDI Kyocera A5521K Speaker Replacement: passo 8, immagine 3 di 3
    • Separate the faceplate from the phone.
  9. KDDI Kyocera A5521K Speaker Replacement, Speaker: passo 9, immagine 1 di 2 KDDI Kyocera A5521K Speaker Replacement, Speaker: passo 9, immagine 2 di 2
    • Turn the phone over.
    • Place a spudger in the oval shaped speaker opening of the phone (indicated by the red rectangle).
    • Turn the phone so the exposed circuit board faces upward.
    • Keep the spudger in the speaker while turning the phone.
    • The speaker is indicated by the yellow rectangle.
  10. KDDI Kyocera A5521K Speaker Replacement: passo 10, immagine 1 di 2 KDDI Kyocera A5521K Speaker Replacement: passo 10, immagine 2 di 2
    • Push the spudger through the speaker opening to separate the speaker (indicated by the yellow rectangle).
  11. KDDI Kyocera A5521K Speaker Replacement: passo 11, immagine 1 di 3 KDDI Kyocera A5521K Speaker Replacement: passo 11, immagine 2 di 3 KDDI Kyocera A5521K Speaker Replacement: passo 11, immagine 3 di 3
    • Grasp the speaker (indicated by the yellow rectangle) with tweezers, or with your fingers if you can manage a firm grip.
    • Firmly remove the speaker.
Conclusione
Cal Poly, Team 28-25, Regan Spring 2010 Membro di Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,831
