Introduzione
A printed circuit board (PCB) mechanically supports and electronically connects electronic components using conductive tracks made of copper laminated onto a non-conductive plastic. The PCB reduces the amount of wires in a device and inherently makes any device more reliable. The step by step instructions will describe how to troubleshoot your PCB.
Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
Aggiungi Commento
Remove the 3 AAA batteries from the device.
  • Remove the 3 AAA batteries from the device.
Aggiungi Commento
  • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
  • Pull apart the device once screws are loose, splitting the device in half.
Aggiungi Commento
  • Keeping all wires connected to their attachments, place the front half of the device face down.
Aggiungi Commento
  • Inspect the printed circuit board for any breaks or cracks.
Aggiungi Commento
  • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
Aggiungi Commento
  • Disconnect all wires from the PCB
  • Remove the damaged PCB from the microphone
  • Place new PCB in the Justin Bieber Concert Microphone.
  • Connect all the wires to the new PCB using this soldering guide.
Aggiungi Commento
Conclusione
Mike Seyman
Membro da: 19/10/2014
425 Reputazione
4 Guide realizzate
Baylor, Team 4-1, Williams Fall 2014 Membro di Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 155
