Salta al contenuto principale
Justin Bieber Concert Microphone On/Off Switch Replacement
Cosa ti serve
  1. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: passo 1, immagine 1 di 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Flathead 1.5 mm Screwdriver
    $5.49
    Compra
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing batteries: passo 2, immagine 1 di 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: passo 3, immagine 1 di 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: passo 3, immagine 2 di 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone On/Off Switch Replacement, Positioning device: passo 4, immagine 1 di 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: passo 5, immagine 1 di 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: passo 5, immagine 2 di 2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  6. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: passo 6, immagine 1 di 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: passo 6, immagine 2 di 2
    • Remove the 2, #8 11.7 mm Phillips Head screws on the On/Off Switch Board
  7. Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: passo 7, immagine 1 di 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: passo 7, immagine 2 di 2
    • Remove On/Off Switch Board from its holding and detach the wires.
    • Replace the On/Off Switch Board with a new one and reattach the wires using this soldering guide
Conclusione
Mike Seyman
Membro da: 10/19/14
437 Reputazione
4 Guide realizzate
Baylor, Team 4-1, Williams Fall 2014 Membro di Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 153
