Salta al contenuto principale
Justin Bieber Concert Microphone Button Replacement
Cosa ti serve
  1. Justin Bieber Concert Microphone Button Replacement, Removing back panel: passo 1, immagine 1 di 2 Justin Bieber Concert Microphone Button Replacement, Removing back panel: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Flathead 1.5 mm Screwdriver
    $5.49
    Compra
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Button Replacement, Removing batteries: passo 2, immagine 1 di 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Button Replacement, Removing back half of device: passo 3, immagine 1 di 2 Justin Bieber Concert Microphone Button Replacement, Removing back half of device: passo 3, immagine 2 di 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Button Replacement, Positioning device: passo 4, immagine 1 di 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Button Replacement, Removing buttons: passo 5, immagine 1 di 2 Justin Bieber Concert Microphone Button Replacement, Removing buttons: passo 5, immagine 2 di 2
    • Remove the buttons by pushing them out from the front of the device. Clean or replace them as needed and place them back into the appropriate slots.
Conclusione
Mike Seyman
Membro da: 10/19/14
437 Reputazione
4 Guide realizzate
Baylor, Team 4-1, Williams Fall 2014 Membro di Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 139
